[Qgis-user] Re: ArcInfo gdb file system
maning sambale
emmanuel.sambale at gmail.com
Sun Apr 24 20:01:37 PDT 2011
Oops, re-reading your message and it seems you are asking a totally
different file format. Apologies, please disregard my answer.
On Mon, Apr 25, 2011 at 10:58 AM, maning sambale
<emmanuel.sambale at gmail.com> wrote:
> Dear Tom,
> By gdb, I suppose you mean Garmin's GDB format:
> http://www.gpsbabel.org/htmldoc-development/fmt_gdb.html
> QGIS can display gps data using the GPX format, you can convert the
> gdb file into GPX format using the GPS Tools plugin. The conversion
> from other format to GPX is under the "Import other" tab. After the
> import, you can view the GPX files using the same plugin under the
> "Load GPX" tab.
> If you need more power with transforming your gdb files to other GPS
> formats, I suggest you try GPSBabel.
> On Mon, Apr 25, 2011 at 3:52 AM, <mtnbiketrail at zzz.com> wrote:
>> How do I handle gdb files? I don't have ESRI program. Does QGIS have a way
>> of importing these?
>> thanks,
>> Tom
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
cheers,
maning
