[Qgis-user] newbie question: grouping polygons in a shapefile
Hinkle, CJon
CJon.Hinkle at health.mo.gov
Fri Apr 29 05:55:17 PDT 2011
Yes! That worked just right. Thank you so much for your help.
CJon
Subject: Re: [Qgis-user] newbie question: grouping polygons in a shapefile
(cc-ing back to the list)
On 04/28/2011 05:55 PM, Hinkle, CJon wrote:
Yes, that is what my District table looks like. I have it both as a DBF file and a CSV. I can import the table into QGIS by adding a vector layer, but for the life of me, I can't find a Join tab in the counties layer properties. I read that there is a join function associated with the fTools plugin, but while it is installed, it is "not in any enabled repository", and I don't know how to enable it.
Sorry, this new Join tab is in the 1.7 version. From your screen shot I guess you're still on 1.6.
So the way to go is indeed with the fTools table join feature. You should find "Join Attributes" under the "Vector->Data Management Tools" menu. In this case you'll have to use the DBF formatted table, and you don't need to add it in advance. Rather there's a "Join dbf Table" browse button to choose it.
Give it a try and let us know...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110429/afc3d1bc/attachment.html>
