[Qgis-user] Pan/Zoom to co-ordinates
jonathanmoules at warwickshire.gov.uk
Wed Aug 3 01:21:46 PDT 2011
I'm guessing those aren't default plugins but I have found them on the
repository. Thanks.
From: "Alister Hood" <alister.hood at synergine.com>
To: <qgis-user at lists.osgeo.org>
Cc: <jonathanmoules at warwickshire.gov.uk>
Date: 03/08/2011 00:06
Subject: Re: [Qgis-user] Pan/Zoom to co-ordinates
There are also two zoom-to-point plugins, which allow you to enter a
scale factor (rather than an actual scale, which you can enter in the
status bar.
> Date: Tue, 02 Aug 2011 16:10:57 +0100
> From: Saber Razmjooei <razmjooeis at faunalia.co.uk>
> To: jonathanmoules at warwickshire.gov.uk
> Cc: qgis-user at lists.osgeo.org
> Message-ID: <1312297857.2115.1.camel at ioio>
> Content-Type: text/plain; charset="UTF-8"
> You can type the coordinate in the status bar (hit enter) and it
centres
> your map there. After that, you can save it as a bookmark.
> Cheers
> Saber
> On Tue, 2011-08-02 at 16:04 +0100, jonathanmoules at warwickshire.gov.uk
> wrote:
> > Simple question - Does QGIS have a Pan/Zoom to coordinates feature?
> > There are a number of pan/zoom tools but I've not found anything
that
> > can do that.
> > Thanks,
> > Jonathan
> > This transmission is intended for the named addressee(s) only and
may
> > contain sensitive or protectively marked material up to RESTRICTED
and
> > should be handled accordingly. Unless you are the named addressee
(or
> > authorised to receive it for the addressee) you may not copy or use
> > it, or disclose it to anyone else. If you have received this
> > transmission in error please notify the sender immediately. All
email
> > traffic sent to or from us, including without limitation all GCSX
> > traffic, may be subject to recording and/or monitoring in accordance
> > with relevant legislation.
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110803/dd1e5e77/attachment.html>
