[Qgis-user] SOLVED : QGIS 1.7 Does not load after installation
Andreas Neumann
a.neumann at carto.net
Tue Aug 9 21:16:40 PDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Thanks for letting us know. It does not surprised me. I ran into all
sorts of issues installing (and running) software ware Kaspersky was the
culprit (including Autodesk, Oracle, pgAdmin3 and others).
If it were for me I would have kicked out Kaspersky already - but it is
not up to me to decide ... unfortunately.
How can one spend money on a piece of software that causes so much trouble?
Andreas
On 08/10/2011 03:22 AM, Nomeneta Saili wrote:
> Thankyou Frank and Duarte,
> The problem was indeed the antivirus that i was using. It blocked some
> of the files from being installed and run.
> I am using Kaspersky Version 6 for workstation.
> Solution i used.
> 1. Pause Kaspersky
> 2. Install QGIS 1.7
> 3. Resume Kaspersky
> 4. Launch QGIS 1.7
> So for other Kaspersky users out there. This is worth a try if you
> guys/gals run into the same problem.
> Cheers!!. And yes QGIS Rocks!!.
> Nome
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJOQgYkAAoJELiCsGDopvBCDdkIAIRGxoBQduZeBQgWmbv7rrWn
jktq9uiFh+7q1EeEf4lJfGDTD1ewUmNDr0oBTHd35yNsfV9eFbdNQX2GoaoyI8F6
nJ7eLzpkFnIMezmMMQVtcAsZqCRituXmGPvdCuMnFew53inB9wpKq9WYRjSHXsMF
ie+stfG61kn6hQHxNn4f3T64OveTKv6bXyzKw3CU+p9lSyK9eMdsKb5VG+UK0YV+
xM/0JOsfgFNIFtrap2koLFgZWG2JN1Eo80geXifeLsjHXQTt2X6TaXAJhFPUC2XY
MsHL/X8ZKoj7ShfSPdv7Wwaw732RT4q68mz1JU9BJfC6oOtePNisDg8RkgLtwng=
=AveX
-----END PGP SIGNATURE-----
