[Qgis-user] free DEM data in QGis
    Alex Mandel
    tech_dev at wildintellect.com
    Thu Aug 11 15:11:28 PDT 2011
For 3D effect on a 2D map, Shaded Relief plugin can make a hillshade
from the DEM.
Thanks,
Alex
On 08/03/2011 01:45 AM, jonathanmoules at warwickshire.gov.uk wrote:
> Hi Torsten,
>         If your question is how do you get the (SRTM) data, try something
> like:
>  http://edcsns17.cr.usgs.gov/NewEarthExplorer/ - Earth Explorer from the
> USGS
> Or http://srtm.csi.cgiar.org/ - or various other places.
>         If you just want to use it as a basemap then I'm guessing you just
> add it like a regular raster. If you want to use it to drape other data
> over so you can do 3D I'm not sure if QGIS could do that or if it would be
> the best solution - there are other open-source GIS's for that.
> Hope that helps.
> Jonathan
> From:   Torsten Lange <tlange at gwdg.de>
> To:     Qgis-user at lists.osgeo.org
> Date:   02/08/2011 23:55
> Subject:        [Qgis-user] free DEM data in QGis
> Sent by:        qgis-user-bounces at lists.osgeo.org
> Hi!
> I'm novice to use free DEM data. I work on a medium (~60km) scale area in
> Germany. It's basically about geology. As don't need accurate DEM data for
> the
> time being I read through google that gtopo30 or (even better ?) DTED data
> from German Aerospace Center may be utilized, which are all free of
> charge.
> Actually I don't know where to start. Could anyone please give some
> comments
> about how would be the general procedure to load those data into QGis?
> Useful
> links are appreciated.
> Thanks in advance,
> Torsten
> Qgis-user mailing list
> This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
