[Qgis-user] Announcing Metatools plugin
    Agustin Lobo
    alobolistas at gmail.com
    Tue Aug 23 02:42:56 PDT 2011
It works fine here, both view and edit, qgis 1.7 from ubuntu binaries
for 10.04 LTS
Agus
2011/8/23 maning sambale <emmanuel.sambale at gmail.com>:
> Editing is OK, viewing metadata I get this:
> Viewer can't be loaded: <type 'exceptions.ImportError'> No module
> named QtXmlPatterns!
> Using qgis 1.7 on mac leopard
> On Tue, Aug 23, 2011 at 5:19 PM, Alexander Bruy
> <alexander.bruy at gmail.com> wrote:
>> Hi,
>> 2011/8/22 maning sambale <emmanuel.sambale at gmail.com>:
>>> I can edit and add metadata but I cannot view existing metadata.  I
>>> get this error:
>>> "Plugin can't be loaded: Qt version must be higher than 4.6.0!
>>> Currently running: 4.7.3"
>>> Looking forward to the Dublin Core template.
>> Can you test 0.1.13 version? We add some changes that probably
>> should fix this issue.
>> Thanks
>> Alexander Bruy
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> Qgis-user mailing list
