[Qgis-user] Error using clipper with mask option
Jaime Palalane
mitasjp at gmail.com
Tue Aug 23 08:35:51 PDT 2011
Olás,
Using a vectorial layer which defines the limit of a basin I am studying
I want to cut a portion of a DEM which is my raster file. For that I
tried to use the clipper function, under Raster Menu (GDAL plugin),
with *mask option* but it returns the error below and as a result a I
got a raster equal to the original. How can I solve this problem? Is
there any other way to cut a portion of a DEM for further specific
analysis of a small portion of my interest?
Ocorreu um erro durante a execução do seguinte código Python: (An error
occurred with the execution of the following Python code:)
File
"/usr/share/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py",
line 27, in someValueChanged
self.emit(SIGNAL("valuesChanged(const QStringList &)"),
self.getArguments())
File "/usr/share/qgis/python/plugins/GdalTools/tools/doClipper.py",
line 105, in getArguments
return self.getArgsModeMask()
line 143, in getArgsModeMask
if self.alphaBandCheck.isChecked():
AttributeError: 'GdalToolsDialog' object has no attribute 'alphaBandCheck'
Versão do Python:
2.7.1+ (r271:86832, Apr 11 2011, 18:37:12)
[GCC 4.5.2]
Versão do QGIS:
1.7.0-Wroclaw Wroclaw, exported
Caminho para o Python: ['/usr/share/qgis/python',
'/home/jp/.qgis/python', '/home/jp/.qgis/python/plugins',
'/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
'/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/Numeric',
'/usr/lib/python2.7/dist-packages/PIL',
'/usr/lib/pymodules/python2.7/gtk-2.0',
'/usr/lib/python2.7/dist-packages/gst-0.10',
'/usr/lib/python2.7/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.7',
'/usr/lib/pymodules/python2.7/ubuntuone-client',
'/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
'/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
'/usr/share/qgis/python/plugins/fTools/tools']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110823/f237454c/attachment.html>
