[Qgis-user] elevation profile
Torsten Lange
tlange at gwdg.de
Thu Aug 25 01:39:46 PDT 2011
Thank you for the trick! Just for those who actually need the raster values
along a line could also use the tool "Profile from Line".
Cheers, Torsten
> >From the main menu, Plugins > Fetch Python plugins ...
> A new window will appear.
> Click on Repositories tab, Add 3rd party repositories
> Click on Plugins tab, within the filter box, type profile tool
> Install the plugin. Select a raster from TOC and draw a line and you will
> see the profile.
> Cheers
> Saber
> > Hi,
> > I managed to load an Aster digital elevation raster (QGis 1.7). What I
> > actually need is an elevation profile along a line. So far I couldn't
> > find the
> > right tool for it. Is there or not?
> > Thank you, Torsten
