[Qgis-user] converting espg 4326
Andreas Neumann
a.neumann at carto.net
Thu Dec 1 00:36:42 PST 2011
hm - what do you mean by that? EPSG 4326 is just one projection format
(like thousands of other projections). All shapefile readers should be
able to deal with it.
In QGIS, when you save to a Shapefiles you can even select the target
projection and it will automatically project the data for you.
Hope this helps,
Andreas
On Thu, 1 Dec 2011 18:31:10 +1000, steve sgalowski wrote:
> is there away to convert espg 4326 to standard shp files , that
> programs can use ?
> Qgis-user mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
