[Qgis-user] Can not use an attribute called LENGTH in calculations
magerlin
MAP at ramboll.dk
Fri Dec 2 02:22:01 PST 2011
I've got a shapefile with an attribute called Length.
If I try to use this attribute in calculations in the Field Calculator for
instance like:
LENGTH / SOMETHING
I then get the error "Invalid expression syntax. The error message of the
parser is: 'syntax error, unexpected '/', expecting '("
If I rename the attribute to something else the problem disappears.
I fear the field calculator is messing up my attribute LENGTH with its own
$length function to calculate the length?
The shape file is here:
http://osgeo-org.1803224.n2.nabble.com/file/n7054195/calc_error.zip
calc_error.zip
Regards Morten
(Qgis 1.7.1 and Win 7)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-not-use-an-attribute-called-LENGTH-in-calculations-tp7054195p7054195.html
Sent from the qgis-user mailing list archive at Nabble.com.
