[Qgis-user] Re: Can not use an attribute called LENGTH in calculations
magerlin
MAP at ramboll.dk
Fri Dec 2 02:54:43 PST 2011
Yves Jacolin-2 wrote
> I get an error with this shapefile: "not a correct data source" (well the
> message is in french actualy).
Strange - I have no problem opening it??
But now I rediscovered another problem - the length function (and the scale
bar) gives totally wrong values (about double up) when using the Google
Mercator projection EPSG:900913 - se my old post
http://osgeo-org.1803224.n2.nabble.com/Errors-with-distances-in-Google-Mercator-Projection-td6845255.html
Regards Morten
(Qgis 1.7.1 and Win 7)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-not-use-an-attribute-called-LENGTH-in-calculations-tp7054195p7054272.html
Sent from the qgis-user mailing list archive at Nabble.com.
