[Qgis-user] Re: [Qgis-developer] Critical problems with 1.7.2 from ubuntu binaries
Alex Mandel
tech_dev at wildintellect.com
Sun Dec 4 11:47:55 PST 2011
The mailing list is on osgeo:
http://lists.osgeo.org/mailman/listinfo/ubuntu
I should probably put that on launchpad somewhere.
Bug reporting should be possible if you have a launchpad account, hmm or
were we using a trac instance for that. I'll have to go check.
Thanks,
Alex
On 12/04/2011 11:01 AM, Etienne Tourigny wrote:
> I just ran into that same problem myself, using Ubuntu 11.04.
> I upgraded qgis to 1.7.2 through synaptic, and got the "Could not open
> CRS database /resources/srs.db<br>Error(14): unable to
> open database file!" error. I had to uninstall qgis and then
> re-install to get it working.
> Where do I file a bug report for ubuntugis packages? The mailing
> list is not active, and the launchpad bugs page does not let me add a
> bug (https://bugs.launchpad.net/~ubuntugis).
> Subscription policy: shows "Restricted Team".
> Here are my QGis packages, there is no reason for multiple libqgis
> packages (1.7.0 and 1.7.1).
> In my opinion. libqgis.1.x.y should be named only "libqgis" for ease
> of use, and the old versions would not be left around causing this
> bug.
> ii libqgis1.7.0 1.7.0~natty1
> Quantum GIS - shared librariesii
> libqgis1.7.1 1.7.1-1~natty1
> libqgis1.7.2 1.7.2-1~natty1
> python-qgis 1.7.2-1~natty1
> Python bindings to Quantum GISii
> python-qgis-common 1.7.2-1~natty1
> Python bindings to Quantum GIS -
> architecture-independent filesii qgis
> 1.7.2-1~natty1
> Geographic Information System (GIS)ii qgis-common
> 1.7.2-1~natty1
> Quantum GIS - architecture-independent dataii qgis-plugin-grass
> 1.7.2-1~natty1
> GRASS plugin for Quantum GISii qgis-plugin-grass-common
> 1.7.2-1~natty1
> GRASS plugin for Quantum GIS - architecture-independent dataii
> qgis-providers 1.7.2-1~natty1
> collection of data providers to Quantum
> GISii qgis-providers-common
> 1.7.2-1~natty1 collection of data
> providers to Quantum GIS - architecture-independent files
> Regards,
> Etienne
> On Fri, Dec 2, 2011 at 5:44 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> I think another way to phrase the question is why doesn't the deb (FYI
>> packages via the update tools are deb files) have a conflict rule that
>> removes the old version?
>> So if you have
>> libqgis1.7.2
>> there should be a conflict rule saying to remove other versions of
>> libqgis1.7.0 libqgis1.7.1
>> It's a little more work to maintain but solves both issues of knowing
>> exactly which version a user has and cleaning up on upgrade.
>> Thanks,
>> Alex
>> On 11/30/2011 09:27 PM, Agustin Lobo wrote:
>>> Just clarifying I was updating through the update manager of ubuntu,
>>> not through the deb files.
>>> Agus
>>> 2011/12/1 Etienne Tourigny <etourigny.dev at gmail.com>:
>>>> I think I misunderstood the problem, the ubuntugis-unstable repos only
>>>> allows 1 version of qgis installed at a time.
>>>> If you need to uninstall qgis-1.7.0 before upgraging to 1.7.2, then
>>>> there surely must be a problem with the upgrade process in the .deb?
>>>> On Wed, Nov 30, 2011 at 5:21 PM, David J. Bakeman <dbakeman at comcast.net> wrote:
>>>>>> shouldn't qgis be packaged in such a way to avoid multiple (minor)
>>>>>> versions of QGIS?
>>>>>> i.e. change the package names to 1.7 instead of 1.7.0 / 1.7.1 / 1.7.2 ?
>>>>>> There really is no need to have the old packages around, especially
>>>>>> with this issue.
>>>>> I respectfully disagree. It's not that the old packages need to be around
>>>>> it's that they are
>>>>> out there already.
>>>>> People have them some people either can't or won't be
>>>>> able to upgrade
>>>>> them and when those people have questions it's important that the developers
>>>>> and others
>>>>> know exactly what version of the software is being discussed.
>>>>>> Regards,
>>>>>> Etienne
>>>>>> On Tue, Nov 29, 2011 at 8:09 AM, Noli Sicad<nsicad at gmail.com> wrote:
>>>>>>>> reproduced the problem by installing on another machine with ubuntu
>>>>>>>> 10.04 . Running qgis from the command line I get:
>>>>>>>> alobo at delia:~$ qgis
>>>>>>>> Warning: loading of qgis translation failed
>>>>>>>> [/usr/share/qgis/i18n//qgis_en_US]
>>>>>>>> Warning: loading of qt translation failed
>>>>>>>> [/usr/share/qt4/translations/qt_en_US]
>>>>>>>> Warning: Couldn't load Python support library: Cannot load library
>>>>>>>> /lib/qgispython: (/lib/libqgispython.so: cannot open shared object
>>>>>>>> file: No such file or directory)
>>>>>>> In ubuntu 10.04 Lucid, you have to install
>>>>>>> - python-qgis 1.7.2~Lucid1
>>>>>>> - python-qgis-common 1.7.2-1~Lucid1
>>>>>>> If you upgrade from other version (e.g. 1.7.0), you have to remove
>>>>>>> first the old version then install 1.7.2.
>>>>>>> Noli
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
