[Qgis-user] Using/visualizing 3D data (Z values)
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Dec 5 03:02:44 PST 2011
Hi Paul
Unfortunately, the current geometry system does not handle z- and
m-values in a sound way.
Some tools consider z and others don't. M-values are even more difficult
as they cannot be accessed by the QGIS API (z-coordinates can be read by
parsing the binary format of the geometry).
An overhaul of the geometry system is planned for version 2.
Regards,
Marco
On 05.12.2011 10:42, Paul Lens wrote:
> Hi all,
> 1. I made a TIN surface, using the interpolation plugin, from a point
> shapefile (with "ALTITUDE" field) and 3D line shapefiles. I lost time
> trying to extract the relevant lines from the line shapefiles without
> loosing the 3D information (Z values of the nodes).
> If I remember well, I first used "Merge Layers" from the mmqgis
> plugin, and it kept the Z information. Than, I used the Intersection
> command in the Vector menu, and the Z information was lost. Finally,
> after manually selecting the relevant lines and using "save as", I got
> the expected 3D line shapefile keeping the Z values.
> Is this loss of Z information a known limitation of the gdal vector
> commands in QGIS (vector menu) and is this limitation affecting all
> these commands? Or did I do something wrong?
> 2. In a second step, I wanted to be able to easily see (through
> labeling a Z field) or ask (with the identify command) those Z values
> from the 3D lines, so as to fine tune the interpretation of the
> topography.
> Again the gdal tool (in Vector menu) "Node Extraction" lost all Z
> information.
> Is there a workaround to create a point shapefile with a Z field? Or,
> at least, to keep the Z values in a point shapefile, rasterize it so
> as to be able to visualize the Z value using the "Identify" command
> on the raster?
> Thanking all the developers for this wonderful program,
Dr. Marco Hugentobler
Sourcepole - Linux& Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111205/01089509/attachment.html>
