[Qgis-user] Python modules (dependencies?)
    Giovanni Manghi
    giovanni.manghi at gmail.com
    Thu Dec 15 09:04:52 PST 2011
On Thu, 2011-12-15 at 17:23 +0200, Alexander Bruy wrote:
> Hi Thomas,
> how you install QGIS: via OSGeo4W or using standalone installer?
> If you use OSGeo4W you can get all dependencies. The standalone
> installer includes some additional deps, but if you need to add another
> packages — install them into Python bundled with QGIS not into
> system wide Python
In this case the standalone should already install all the necessary
python dependencies, while using osgeo4w you will need to add them
manually looking into the "libs" category when using the "advanced"
install mode.
In this case the pyhton error you are getting seems not related to a
dependency problem, but you can extract isolines using the "contour"
tool in the "raster" menu, as Paolo pointed.
By the way Thomas, is the Navy interested in supporting QGIS? :)
cheers
-- Giovanni --
