[Qgis-user] question for csv import with color
henry cui hhenry.cui at gmail.com
Sat Dec 24 04:14:43 PST 2011
hi Richard,
    thanks for reply.
    The way of Categorized Style surely make the dot seem different.But I
hope to put all thing predefined in that csv file,because
I need output the csv from another software and then import qgis to get the
glance of whole state of these dots.This operations will be a little bit
more frequent and the dot actually has three or more different states,so I
want to simply the operations as much as possible.
I guess put everything in that a single file is a simple way but i dont't
know wether it is feasible in QGIS?
henry cui
2011/12/24 Richard Duivenvoorde <rdmailings at duif.net>
> On 2011-12-24 09:19, henry cui wrote:
> >    I want to import csv with lots of dots something with states.the
> > states of some is good,and other is bad.I want to define good as green
> > color and bad for red in csv file.
> > I want to see the dot with different color when I finished import,but I
> > don't know how to manipulate in the qgis.any suggest? thanks.
> Hi Henry,
> what is the column format of the csv? Is there already some column in
> the data on which you can 'know' if the point is good or bad?
> If that is the case, you can use the 'Add Delimited Text Layer'-plugin
> to just load your dat in QGIS.
> Then you use a 'Categorized Style' (see 'Layer
> Properties'/Style-tab/...) and choose the column with your two states
> good/bad.
> Push button 'Classify' and optionally change color by clicking on the
> colored dots in that dialog.
> Both for using the 'Add Delimited Text Layer'-plugin and about
> Categorized classification for styles, see documentation:
> http://qgis.org/en/documentation/manuals.html
> Hope this helps,
best,
henry cui
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111224/01707602/attachment.html>
