[Qgis-user] Re: Swap Line Direction
    Gissur Þórhallsson
    gissur at loftmyndir.is
    Fri Dec 30 03:25:47 PST 2011
Hi Nathan,
Thank you for your quick reply.
It worked like a charm after I checked "Show all plugins, even those marked
as experimental"
I didn't need the repo after all.
Kind regards,
Gissur
2011/12/30 Nathan Woodrow <madmanwoo at gmail.com>
> Hi Gissur,
> The swap line tool should be in the new plugin repo that QGIS is now
> using.  You will have to add http://plugins.qgis.org/plugins/plugins.xmlto the plugin installer to get access to the new repo.
> - Nathan
> 2011/12/30 Gissur Þórhallsson <gissur at loftmyndir.is>
>>  Hi,
>> I was looking for a way to swap line directions in qgis and ran across
>> this discussion from earlier this year:
>> http://osgeo-org.1803224.n2.nabble.com/flip-vector-line-direction-td6815277.html
>> I can not find this plugin in the plugin installer inside qgis.
>> I found a link to a zip file here:
>> http://pyqgis.org/manager/python_plugin/list - except that the domain it
>> points to seems to have succumbed to web-rot.
>> Can anybody point me in the right direction?
>> Gissur Þórhallsson
>> Loftmyndir ehf.
>> Laugavegur 13
>> IS 101 Reykjavík - Iceland
>> sími (tel): (+354) 540 2500
>> tölvupóstur (email): gissur at loftmyndir.is
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Gissur Þórhallsson
Loftmyndir ehf.
Laugavegur 13
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111230/8ddfd823/attachment.html>
