[Qgis-user] Re: QGIS File Browser1.1: no raster layers listed
    Agustin Lobo
    alobolistas at gmail.com
    Wed Feb  2 00:04:22 PST 2011
You are right, I probably went too fast. But my error has unveiled another
problem. The
name of my ecw file includes a "ç" (c,), like in "Françoise". If I select
the file with your plugin I
get the following error:
An error has occured while executing Python code:
  File
"/home/alobo/.qgis/python/plugins/QGISFileBrowser/qgisfilebrowserdialog.py",
line 156, in itemClicked
    if os.path.isdir(filepath):
  File "/usr/lib/python2.6/genericpath.py", line 41, in isdir
    st = os.stat(s)
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe7 in position 121:
ordinal not in range(128)
This also happens with a jpg file and is solved by renaming the "ç" to "c"
in both cases.
Regarding *.sid files, you see them if the filter is set to *.sid, but not
"All raster files" or "All supported files"
Agus
View this message in context: http://osgeo-org.1803224.n2.nabble.com/QGIS-File-Browser1-1-no-raster-layers-listed-tp5976874p5983933.html
Sent from the qgis-user mailing list archive at Nabble.com.
