[Qgis-user] Problem with version sip module
Rainer M Krug
r.m.krug at gmail.com
Mon Feb 7 02:19:39 PST 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 02/05/2011 01:55 AM, Noli Sicad wrote:
Hi Noli
> Try to use the compatible python-qgis with qgis.
> if not, try the trunk.
> http://www.qgis.org/wiki/Download#Ubuntu
There is a third option: downgrade python-sip and python-qt4 to the one
in the official maverick repo - I used the kubuntu beta repo, which has
the newer version of those.
Thanks,
Rainer
> Noli
> On 2/5/11, Rainer M Krug <r.m.krug at gmail.com> wrote:
> Hi
> after not using qgis for some time and several ypgrades inbetween, I get
> the following eror message when starting qgis:
> Couldn't load PyQGIS.
> Python support will be disabled.
> Traceback (most recent call last):
> File "", line 1, in
> RuntimeError: the sip module implements API v8.0 but the qgis.core
> module requires API v7.1
> Python version:
> 2.6.6 (r266:84292, Sep 15 2010, 16:02:57)
> [GCC 4.4.5]
> QGIS version:
> 1.6.0-Trunk 'Trunk', exported
> Python path:
> ['/usr/share/qgis/python', '/home/rkrug/.qgis/python',
> '/home/rkrug/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
> '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
> '/usr/lib/python2.6/lib-dynload',
> '/usr/local/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages/PIL',
> '/usr/lib/python2.6/dist-packages/gst-0.10',
> '/usr/lib/pymodules/python2.6',
> '/usr/lib/python2.6/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.6/gtk-2.0',
> '/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode']
> The version of python-sip which is installed is:
> 4.11.2-0ubuntu1~maverick1~ppa1
> I am running Maverick, all updates.
> Cheers,
> Rainer
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Natural Sciences Building
Office Suite 2039
Stellenbosch University
Main Campus, Merriman Avenue
Stellenbosch
South Africa
Tel: +33 - (0)9 53 10 27 44
Cell: +27 - (0)8 39 47 90 42
Fax (SA): +27 - (0)8 65 16 27 82
Fax (D) : +49 - (0)3 21 21 25 22 44
Fax (FR): +33 - (0)9 58 10 27 44
email: Rainer at krugs.de
Skype: RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk1PxzoACgkQoYgNqgF2egpMCwCcCf9aeSQNfdm5CaR3xEj/+ALu
o7kAoITX83JL3bjohIwnGtyVI7DJujJg
=GgFX
-----END PGP SIGNATURE-----
