[Qgis-user] printing with google layers
Markus Weidenbach landconsult at freenet.de
Tue Feb 8 01:58:58 PST 2011
Hi Jonathan,
faced the same problem recently, and if I understood right it is a
limitation of the Google WMS. I think the "capabilities" of the WMS
description tells you if you can print and what size (if I remember
right the parameter is called "map extend", but I am not sure .. if this
is set to 0, you can´t print anything. A possible workaround is to make
a screenshot of the Google layer and open it in the map composer as a
background photo (you can use the "save image" under the "File" menu in
QGIS), another possibility is to reduce the size of your area to be
printed, maybe you are allowed to print a smaller part ....
Regards,
Markus
Dr. Markus Weidenbach
*landConsult.de*
Geographical Information Management
and Environmental Planning
D-77773 Schenkenzell
Germany
e.mail see: http://landConsult.de
Am 07.02.2011 14:37, schrieb jonathan ALLAIN:
> Hello,
> I try to print a map with an "open layer" layer (google satellite).
> However I always obtain a grey square instead of the satellite view.
> Is it a problem or is it a limitation of google ?
> how can I bypass this problem ?
> Thanks.
> Jonathan ALLAIN
> Communauté d'Agglomération
> du Pays de Flers
> 02 33 98 44 58
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110208/e7e0c454/attachment.html>
