[Qgis-user] Legend orientation
Andreas Neumann a.neumann at carto.net
Sun Feb 13 23:14:42 PST 2011
Hi Brett,
This is currently not possible. You can do it "manually" though. You can
use three times the same legend and manually remove the entries that are
in the other two columns. Not so elegant, I know, but at least a
workaround now.
I once ran into the same issue and would like to see that problem solved
more elegantly.
Andreas
On 2/14/11 3:24 AM, Brett Adams wrote:
> Hi Folks,
> Is it possible to change the layout of the Legend? I need it to
> contain 2-3 colombs so it can be stretched horizontally along the
> bottom of the page. Its just what fits.
> Thanks
