[Qgis-user] Legend orientation
Brett Adams badams at spinifexgeophysics.com.au
Mon Feb 14 17:06:31 PST 2011
Those tickets pretty much cover it. Given they are both 2 years old I
guess its not a real high priority.
Ho-hum.:-(
On 14/02/2011 6:38 PM, Alister Hood wrote:
> Hi guys,
> There is the "horizontal legend" request
> https://trac.osgeo.org/qgis/ticket/1841
> and the "column wrapping in legend" request
> https://trac.osgeo.org/qgis/ticket/1505
> These might not be exactly what you're talking about, but they might
> be similar enough that the functionalities each of you want could
> all be achieved; if some thought is put into how to do it.
> Regards,
> Alister
>> Date: Mon, 14 Feb 2011 08:18:56 +0100
>> From: Paolo Cavallini<cavallini at faunalia.it>
>> Subject: Re: [Qgis-user] Legend orientation
>> To: Andreas Neumann<a.neumann at carto.net>
>> Cc: qgis-user at lists.osgeo.org
>> Message-ID:<1297667936.3428.11.camel at ursus.ufficio.net>
>> Content-Type: text/plain; charset="UTF-8"
>>> This is currently not possible. You can do it "manually" though. You
>> can
>>> use three times the same legend and manually remove the entries that
>> are
>>> in the other two columns. Not so elegant, I know, but at least a
>>> workaround now.
>> Brett:
>> could you please check whether there is an open ticket on this, and if
>> not opening it?
>> Thanks.
>> http://www.faunalia.it/pc
> Qgis-user mailing list
Brett Adams
Spinifex Geophysics <http://www.spinifexgeophysics.com.au/>
0438 861 974
SKYPE:brettadams_spinifex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110215/ab267a2f/attachment.html>
