[Qgis-user] RE: Qgis-user Digest, Vol 60, Issue 21
Alister Hood
alister.hood at synergine.com
Mon Feb 14 20:12:05 PST 2011
Hi Ramon,
> Date: Tue, 15 Feb 2011 09:46:09 +0800 (WST)
> From: custard <custard at westnet.com.au>
> Subject: [Qgis-user] Delimited Text Plug-in claiming text file not
> valid
> To: qgis-user at lists.osgeo.org
> Message-ID:
> <550194667.539501297734369648.JavaMail.root at zim-
> store03.web.westnet.com.au>
> Content-Type: text/plain; charset="utf-8"
> Hi,
> I like the revamp of the Delimited Text Plugin in trunk - it feels
much
> easier to use.
> However...
> While opening a file today I noticed that I didn't get an oppertunity
> to define a CRS for the file - which I used to in 1.6.
> Before reporting that I thought I'd update trunk (which is now
revision
> 15172) and am getting a completly different error from the same file.
> It says:
> The layer M:/Data/WesternAustralia/SH51-
09/Anthill/MMAnthill/Exports/20110215MKOAHCollars.csv?delimiter=%5B,%5D
> &delimiterType=regexp&xField=East_LG&yField=North_LG is not a valid
> layer and can not be added to the map
I've noticed the same thing this afternoon, and was about to try to
isolate the cause so as to file a bug report.
I also updated GDAL and maybe some other things at the same time as QGIS
- did you do the same, or did you only update QGIS?
> I've reinstalled trunk (which reinstalled the plugin) to no effect.
> Does anyone have any other suggestions.
Thanks, at least I now know that is not the solution :)
> I can open this file in 1.6 with little or no problems.
> Also, in the first situation, if a file is opened in the wrong CRS, is
> there a way to redefine the CRS - withouth having the points
converted?
> (I'm guessing I could edit the .prj file - would that be right?)
> Thanks,
> Ramon.
Regards,
Alister
