[Qgis-user] relative paths of texture fill images
John Callahan
john.callahan at udel.edu
Tue Feb 15 07:42:10 PST 2011
I found an inconsistency with styles that contain relative oaths to texture
fill images. I have a polygon shapefile that uses png images as texture
fills. In my style file (.qml), if the path to the image file is relative
(<texturepath>./fill.png</texturepath>), then that texture fill is NOT found
and left blank. If the path is absolute
(<texturepath>C:\data\images\peg.png</texturepath>), then it displays
fine. I also tried variants of the paths, such as simply fill.ong or
.\fill.png.
However, when opening a QGIS project file (.qgs) with the style included, it
doesn't matter if it's relative or absolute. The texture fill images
display fine either way.
- John
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110215/c4e69c15/attachment.html>
