[Qgis-user] QGIS compiling problem sqlite3
Alessandro Sarretta
alessandro.sarretta at inwind.it
Tue Feb 15 23:54:51 PST 2011
Hi Paolo,
On 13/02/11 21:40, Paolo Cavallini wrote:
> Why not using the usual route, via ccmake?
I'm following the procedure here
https://svn.osgeo.org/qgis/trunk/qgis/INSTALL
is it not the usual one?
Thanks
Ale
3.7. Starting the compile
I compile my development version of QGIS into my ~/apps directory to avoid
conflicts with Ubuntu packages that may be under /usr. This way for example
you can use the binary packages of QGIS on your system along side with your
development version. I suggest you do something similar:
mkdir -p ${HOME}/apps
Now we create a build directory and run ccmake:
cd qgis
mkdir build
cd build
ccmake ..
When you run ccmake (note the .. is required!), a menu will appear where
you can configure various aspects of the build. If you do not have root
access or do not want to overwrite existing QGIS installs (by your
packagemanager for example), set the CMAKE_BUILD_PREFIX to somewhere you
have write access to (I usually use /home/timlinux/apps). Now press
'c' to configure, 'e' to dismiss any error messages that may appear.
and 'g' to generate the make files. Note that sometimes 'c' needs to
be pressed several times before the 'g' option becomes available.
After the 'g' generation is complete, press 'q' to exit the ccmake
interactive dialog.
Now on with the build:
make
make install
> Il giorno dom, 13/02/2011 alle 21.30 +0100, Alessandro Sarretta ha
> scritto:
>> Hi QGIS list,
>> I'm trying to compile QGIS from source as I did some months ago without
>> problems. I'm working in Ubuntu 10.10.
>> This time after the "make" command I receive this message:
