R: Re: [Qgis-user] FTOOLS Calculate Area error
enricofiore at libero.it enricofiore at libero.it
Fri Feb 18 01:35:44 PST 2011
I check and there's not ticket opens for this specific problem. I opened one
ticket, but I aren't sure to report in the correct way. Can you control?
https://trac.osgeo.org/qgis/ticket/3500
thanks
Enrico
----Messaggio originale----
Da: cavallini at faunalia.it
Data: 18/02/2011 9.34
A: "enricofiore at libero.it"<enricofiore at libero.it>
Cc: <qgis-user at lists.osgeo.org>
Ogg: Re: [Qgis-user] FTOOLS Calculate Area error
Il giorno mer, 16/02/2011 alle 21.30 +0100, enricofiore at libero.it ha
scritto:
> Hi,
> I try to calculate area with ftools add geometry column. I have noted that
in
> automatic new field “AREA” have this properties type=real lenght=10
> precision=6, this involve an error, some numbers are lost, because the Area
> number have lenght>10.
> Example: if I calculate Piedmont area with Ftools obtain 2539107283
> if I calculate the same Area , add new column (type real lenght=20
> precision=5) and use calc field ($area) I obtain 25391072834.9971.
Hi Enrico.
Thanks for the report. Have you checked that there is no ticket open on
this? If not, please open one, not to miss this issue.
All the best.
http://www.faunalia.it/pc
