[Qgis-user] Ecological toolbox for QGIS - collecting ideas
Rainer M Krug
r.m.krug at gmail.com
Thu Feb 24 01:35:11 PST 2011
On Thu, Feb 24, 2011 at 10:18 AM, Matt Boyd <mattslists at gmail.com> wrote:
> I wouldn't find an ecological system very useful but....
> Would it be possible to implement custom menu items and configurations. Ie,
> someone could assemble the ecological tools in a logical way in one or more
> menu items or toolbars and share this menu via the plug installer.
If you add the possibility to add dependencies to other plugins, then
you have exactly what I suggested - with less words.
Cheers,
Rainer
> On 24/02/2011 7:03 PM, "Rainer M Krug" <r.m.krug at gmail.com> wrote:
>> On Thu, Feb 24, 2011 at 6:52 AM, Dr. F. Patrick Graz <fgraz at unam.na>
>> wrote:
>>> Hi all,
>>> I just had a quick look at the hyperlinks that were provided by the
>>> original
>>> posting. The collections seem quite useful. Many of these are, however,
>>> already included in QGIS e.g. in the ftools or the home range manager.
>>> While an ecological toolbox would be quite a useful thing, it can also
>>> lead
>>> to some confusions / errors. For instance, using another GIS package I
>>> obtained different results from two different buffering pluggins. So
>>> which
>>> one is correct? Also remember, that ArcGIS was (apparently) originally
>>> produced because Arc/INFO (7.x) and ArcView 3.2 produced different
>>> outcomes
>>> in calculations.
>>> I would suggest as an alternative that a set of "how to's" is produced
>>> (maybe in conjunction with the qgis web-site) that shows how the
>>> different
>>> analysis tasks are carried out. This way we a) increase the utility of
>>> the
>>> exiting pluggins is enhanced and b) if there are errors in a pluggin they
>>> are more readily identified.
>> You are raising good points - but I think with an howto, the problem
>> is not solved for ecologists. I am an ecologist myself, so I am
>> allowed to say that most of the ecologists I know would like to have
>> one menu which gives them all routines for an analysis, without having
>> to read through an howto, install several plugins, dig into different
>> menus, ...
>> But to avoid duplication, these already implemented routines should
>> definitely not be re-implemented in a new plugin.
>> But: I am not familiar with the plugin structure, but is it possible
>> to create dependencies? I.e. my suggestion would then be tio have one
>> "Ecological Toolbox" plugin, which consists of analysis methods not
>> implemented already, plus is dependent (i.e. loads, installs, ...)
>> several other plugins which contain ecological analysis methods. All
>> these methods (internal and in other packages) are then all displayed
>> under one menu "Ecological toolbox".
>> This would avoid duplication and bring many different ecological
>> methods in one menu.
>> By the way: this approach could be used for creating other Toolboxes /
>> Metaplugins which simply install other plugins and create menues in
>> which these are grouped under one topic.
>> Cheers,
>> Rainer
>>> Regards,
>>> Patrick
>>> Dr. F. Patrick Graz
>>> Snr. Researcher,
>>> Multidisciplinary Research Centre,
>>> University of Namibia
>>> **************************UNAM
>>> DISCLAIMER***********************************
>>> *This e-mail is strictly confidential and intended only for use by the
>>> addressee unless otherwise indicated.*
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> NEW GERMAN FAX NUMBER!!!
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Natural Sciences Building
>> Office Suite 2039
>> Stellenbosch University
>> Main Campus, Merriman Avenue
>> Stellenbosch
>> South Africa
>> Cell: +27 - (0)83 9479 042
>> Fax: +27 - (0)86 516 2782
>> Fax: +49 - (0)321 2125 2244
>> email: Rainer at krugs.de
>> Skype: RMkrug
>> Google: R.M.Krug at gmail.com
Office Suite 2039
Stellenbosch
South Africa
Skype: RMkrug
