[Qgis-user] PostGIS viewer -PgAdmin plugin
Germán Carrillo
carrillo.german at gmail.com
Fri Feb 25 14:03:28 PST 2011
Hi Ivan,
I am going to check those 2 points, I had not checked the linear units.
Actually, I started with the first version of your viewer and I did not
realize the 'Layer properties' until it was too late. It makes sense to
display some properties for a layer, so, sure!
Regards,
Germán
2011/2/25 Ivan Mincik <ivan.mincik at gmail.com>
> I have uploaded Your version to Github [1] under 'multilayer' branch.
> Do You have any plans to recreate bottom 'Layer properties' window to
> support multiple layers ? If this would be done, I will completely
> turn to Your version.
> Thanks,
> Ivan
> [1] - https://github.com/imincik/QgsPostGIS-Viewer/tree/multilayer
> Qgis-user mailing list
|\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110225/05fb4f79/attachment.html>
