[Qgis-user] Re:Newbie question - gml files
Sam Vekemans
acrosscanadatrails at gmail.com
Sun Jan 2 15:58:49 PST 2011
That makes sence.
Since there are older versions running, the program doesn't know where
to turn to, to look for the files :)
... also, i have the programs running on the d: drive rather than the
c: drive, so that will also make a difference. I need to clean up my
hard drive anyway as this program needs alot of space to work in.
cheers,
sam
On 1/2/11, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Sam,
> I think you have to uninstall the previous installation of QGIS in Add
> / Remove or in Uninstall QGIS (I am not using Windows right now so I
> don't exactly know). If not remove manually the QGIS directory and
> install again.
> QtCore4.dll is Qt library for Qt window toolkit which included in
> QGIS. QGIS will not work without the dynamic library.
> FWTools is not part of the QGIS, you don't probably need it if you
> have work the org2org.exe program in gdal already.
> Noli
> On 1/3/11, Sam Vekemans <acrosscanadatrails at gmail.com> wrote:
>> thanks
>> will try 4326 instead .... and just remove that last program that
>> doesnt help. :)
>> cheers,
>> sam
>>> Hi,
>>>> it took some time to number crunch, but it did make a whole bunch of
>>>> .shp
>>>> files :) ... accept the projection is still off.
>>>> So i need to add "EPSG : 4617" or some random 4 digit number that will
>>>> work.
>>>> ogr2ogr.exe -f "ESRI Shapefile" -t_srs EPSG:4617 d:\try3-gdal NL_LX.gml
>>>> What i dont know is exactly which projection code to use or the prefix
>>>> to
>>>> use for it. http://www.gdal.org/ogr2ogr.html assumes that the user
>>>> already
>>>> knows how to use the program :)
>>>> ... if i get this right then there is no need to mess with qgis :-)
>>> Try,
>>> EPSG: 4326 for WGS84
>>> http://nsidc.org/data/atlas/epsg_4326.html
>>> This is the metafile of one of the file.
>>> General:
>>> Storage type of this layer: GML
>>> Source for this layer:
>>> /home/noli/Downloads/A_NZ/NL_EN/NL_EN.gml|layername=EN_1360049_0
>>> Geometry type of the features in this layer: Point
>>> The number of features in this layer: 3
>>> Editing capabilities of this layer:
>>> Extents:
>>> In layer spatial reference system units : xMin,yMin 48.4084,-66.6146 :
>>> xMax,yMax 54.472,-55.0224
>>> Layer Spatial Reference System:
>>> +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
>>> Noli
>> Twitter: @Acrosscanada
>> Blogs: http://acrosscanadatrails.posterous.com/
>> http://Acrosscanadatrails.blogspot.com
>> Facebook: http://www.facebook.com/sam.vekemans
>> Skype: samvekemans
>> IRC: irc://irc.oftc.net #osm-ca Canadian OSM channel (an open chat room)
>> @Acrosscanadatrails
Skype: samvekemans
@Acrosscanadatrails
