[Qgis-user] data defined labelling field details?
Andreas Neumann
a.neumann at carto.net
Sun Jan 9 03:35:53 PST 2011
Maybe we could introduce tooltips with sample values or explaining which
data type QGIS expects?
Andreas
On 1/8/11 11:06 PM, Marco Hugentobler wrote:
> Hi William
> Do you use the new labeling?
> If yes:
> bold/italic/underline/strikeout expect int (0 means false )
>> Spell out placement strings? ("Above Left", ...) Or some sort of
>> abbreviations? Or maybe it's an integer lookup of the placements?
> Strings
> For horizontal alignment: 'Left', 'Center', 'Right'
> For vertical alignment: 'Bottom', 'Base', 'Half', 'Top'
>> Color - RGB values (in a char field)?
> Hex representation, e.g. #ff0000 for red
> Regards,
> Marco
> Am Samstag, 8. Januar 2011, um 19.20:21 schrieb William Kyngesburye:
>> I want to try some data defined labelling, but I could not find any info
>> about how to configure data fields.
>> Some of them look obvious, like integers or floats/reals for sizes and
>> offsets, and character/varchar for font.
>> Maybe boolean for bold/italic/underline/strike? Or does Qgis want a char
>> representation of a boolean for these?
>> Placement I think should be a char field, but what are the values to use?
>> Color - RGB values (in a char field)? what separator to use?
>> Any other details other details I didn't think of to ask about?
>> William Kyngesburye<kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "Those people who most want to rule people are, ipso-facto, those least
>> suited to do it."
>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
