[Qgis-user] plugin ras
Michele Beneventi
mbeneventi at gmail.com
Tue Jan 11 08:57:54 PST 2011
Hi Gianni,
I work on a windows XP pro 64-bit SP2 with Qgis 1.6 e the plug in works fine.
regards
Michele
On Tue, Jan 11, 2011 at 5:26 PM, Gianni Deiana <agr.gdeiana at gmail.com> wrote:
> seen both, but the procedure
> sardegna territorio indicated on the plugin
> not installed in mac os x snow leopard or
> in windows xp pro
> regards
> 2011/1/11 Michele Beneventi <mbeneventi at gmail.com>
>> hi,
>> have you ever seen this? [0]
>> To install manually you could read this. [1]
>> [0] http://www.kyngchaos.com/software/qgis
>> [1] http://www.sardegnaterritorio.it/j/v/1293?s=151868&v=2&c=7376&t=1
>> regards
>> Michele
>> On Tue, Jan 11, 2011 at 4:46 PM, Gianni Deiana <agr.gdeiana at gmail.com>
>> wrote:
>> > Good evening Michael,
>> > I thank you for the swift response.
>> > Version 1.6 is not installed copiacapo
>> > mac os snow leopard, so I made use of
>> > kore version (1.0.0).
>> > How do I install it manually in this
>> > and / or in other versions? es. I use Windows XP 1.3.0
>> > Mimas.
>> > Thank you, Gianni Deiana
>> >> Hi Gianni,
>> >> you can install the TMS RAS Plugin with the qgis plug in installer or
>> >> manually.
>> >> This release is optimized for the 1.5 release but works fine on
>> >> "Copiapo" as well.
>> >> regards
>> >> Michele
>> >> On Tue, Jan 11, 2011 at 4:15 PM, Gianni Deiana <agr.gdeiana at gmail.com>
>> >> wrote:
>> >> > how to install plug-ras in quantum gis?
>> >> > tanks
>> >> > _______________________________________________
>> >> > Qgis-user mailing list
>> >> > Qgis-user at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
