[Qgis-user] Re: using EPSG:1662 transformation
Michele Beneventi
mbeneventi at gmail.com
Mon Jan 17 05:11:16 PST 2011
hi all,
Update.
After severals test I couldn't reproject in a properly way my
shapefile from 32632 to 3003 with transformation 1662 and of course
with ftools.
Am I missing something?
How can I customize a reprojection with a specific transformation (in
ths case the 1662) with ftools??
best regards
Michele
On Fri, Jan 14, 2011 at 4:58 PM, Michele Beneventi <mbeneventi at gmail.com> wrote:
> Hi all,
> I'm using Qgis 1.6 release on windows xp pro 64-bit and in particulary
> "export to new projection" (ftools).
> I need to reprojct a layer from WGS84 / UTM zone 32N (EPSG:32632) to
> Monte Mario / Italy zone 1 (EPSG:3003) with the transformation 1662
> (EPSG code).
> I try to insert the value of the transformation in "custom CRS" with
> proj4 syntax (+proj=tmerc +lat_0=0.0 +lon_0=9.0 +k=0.9996
> +x_0=1500000.0 +y_0=0.0 +ellps=intl +units=m
> +towgs84=-168.6,-34,38.6,-0.374,-0.679,-1.379,-9.48 +units=m +no_defs)
> and create a new CRS target, but it seems doesn't work properly..
> With gdalwarp I can put this value in the "-t_srs" parameter and run
> the command with execellent results.
> There is another way to customize the reprojection tool with the value
> of local parameters?
> Thanks in advance
> regards
> Michele
