[Qgis-user] Intersection between vector layers
Nicholas.Crosbie at health.vic.gov.au
Mon Jan 24 21:47:59 PST 2011
Thanks Noli.
The approach I took was (following a hint from Alex from "Wild Intellect")
was:
1. to make a new shape file from my yellow polygon, (Layer > Save
Selection as Vector file ...)
2. importing the new layer and placing the "dots" layer above the new
layer, then
3. Vector>Research Tools>Select by location... and follow the GUI
instructions
This did exactly what I needed.
A great tool!
best regards,
Nick
Noli Sicad <nsicad at gmail.com>
To:
Cc:
qgis-user at lists.osgeo.org
Date:
25/01/2011 03:18 PM
Subject:
Re: [Qgis-user] Intersection between vector layers
Hi Nick,
I think there are two ways to accomplish this,
1, Select the yelllow polygon using the "Select Features" tool then
Tools > Geoprocessing Tools > Intersect. Create a new shapefile in
"Output Shapefile" and "OK"
or
2. Using the "Select Features" tool again, Press Control button,
select all the points in inside the polygon and then Tools >
Geoprocessing Tools > Clip. Create a new shapefile in "Output
Shapefile" and "OK"
Noli
On 1/25/11, Nicholas.Crosbie at health.vic.gov.au
<Nicholas.Crosbie at health.vic.gov.au> wrote:
> Hi Noli,
> Thanks for your email.
> I attach the screen grab.
> The small circles (aka 'dots') are all on one layer. Then there is
> another layer which displays adjoining polygons (this holds the
> yellow, selected, polygon).
> I want to select only those circles that are in the yellow (selected)
> polygon.
> How do I do that?
> cheers,
> Nick
_________________________________________________________________________________
> This email contains confidential information intended only for the
person
> named above and may be subject to legal privilege. If you are not the
> intended recipient, any disclosure, copying or use of this information
is
> prohibited. The Department provides no guarantee that this communication
is
> free of virus or that it has not been intercepted or interfered with. If
you
> have received this email in error or have any other concerns regarding
its
> transmission, please notify Postmaster at dhs.vic.gov.au
This email contains confidential information intended only for the person named above and may be subject to legal privilege. If you are not the intended recipient, any disclosure, copying or use of this information is prohibited. The Department provides no guarantee that this communication is free of virus or that it has not been intercepted or interfered with. If you have received this email in error or have any other concerns regarding its transmission, please notify Postmaster at dhs.vic.gov.au
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110125/9a2f559c/attachment.html>
