[Qgis-user] How to Identify the best subdataset of a dataset of	points which follow a canonical distribution ?
    Anita Graser
    anitagraser at gmx.at
    Tue Jan 25 03:52:34 PST 2011
Hi Nikos,
I think this would be a perfect question for gis.stackexchange.com
A manual approach (135 stations is not that much) would be to decide on a
maximum distance between stations (depends on your analysis requirements I
guess) and then buffer the station points accordingly. You can then manually
remove points with redundant/overlapping geographic coverage.
But I'm sure there are better solutions :)
Best wishes,
Anita
On Tue, Jan 25, 2011 at 12:09 PM, nikos <vesnikos at gmail.com> wrote:
> Hello List,
> I have an interesting problem, and I'd really appreciate if you could
> give a couple insightful tips on how you'd solve the following:
> I want to order some meteo (rain mm/month for PSDI) data from my
> corresponding national agency, but in their infinitive wisdom they
> choose to place their weather stations in a pattern that follows
> anything but a canonical distribution.
> I know this because they sent me a shp file with all their 136 stations
> which are available to the general public - for a fee of couse.
> Now my problems arise on how I choose  which possible combination of my
> dataset of stations correspond to a canonical distribution of the
> mainland - keeping the set of the stations to a minimum as with each
> station the cost goes up?
> I want to be as much efficient one can be using GIS technology ;)
> My initial thinking is to find a subdataset which have their voronoi
> polygons created with the same area. But im not so sure if thats the
> correct approach
> Any tips on how to solve this problem is greatly appreciated!
> Ves Nikos
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110125/640473b6/attachment.html>
