QTCore4.dll Error (was Re: [Qgis-user] bug)
Micha Silver
micha at arava.co.il
Fri Jan 28 07:53:53 PST 2011
On 01/28/2011 08:34 AM, Sam Vekemans wrote:
> Probably the reminence of when i attemped to install 'Qt Operating
> system' .... so leftovers that have gone stale....
> Perhaps i need to wipe my system and re-install windows back to
> factory settings.
> .... can others confirm that qgis 1.6 works fine on windowsXP? ... i
> assume so. So it MUST be in my computer that has the bug.
I've installed QGIS on several dozen WinXP computers. The only case
where I had to do something "unusual" was on WinXP pre SP2. In these
cases I added the MS Visual C++ redistributable package from:
http://www.microsoft.com/downloads/en/details.aspx?familyid=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en
<http://www.microsoft.com/downloads/en/details.aspx?familyid=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en>
Have a look at this forum post:
http://forum.qgis.org/viewtopic.php?f=2&t=4812&p=8261&hilit=redistributable#p8261
<http://forum.qgis.org/viewtopic.php?f=2&t=4812&p=8261&hilit=redistributable#p8261>
Other than that, it most certainly works... I think cleaning out traces
of older QT installations would probably help. (If you don't need that
software anymore)
> cheers,
> Sam
> On 1/27/11, Alister Hood<alister.hood at synergine.com> wrote:
>>> The problem is probably due to other QT libraries (i.e. not
>>> QtCore)
>>> Never met QtCore ...
>> QtCore4.dll was the one in the screenshots you posted.
>>> qgis 1.4 without GRASS works just fine... and it has a nice
>>> 'uninstaller' the error was introduced in 1.5 and carried into 1.6,
>>> and does not include an uninstaller.
>>> Hopefully, qgis 1.7 will include an uninstaller, and not include
>> GRASS.
>>> (If i wanted to install GRASS, then i would go to that website and
>>> install it) .... and i did install it, and it requires a big learning
>>> curve...
>>> As this might solve the problem, .. maybe by that time i'll have
>>> figured it out :-)
>> Sure... but if the errors were all in the QT libraries then I don't
>> think GRASS can be the problem. Maybe QGIS 1.4 is compatible with the
>> libraries in your system directory. Or maybe it is somehow set up
>> differently, so it can't see them...
>> Alister
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
