[Qgis-user] Grass Plugin
Brad Nesom
gisbradokla at live.com
Fri Jan 28 11:30:01 PST 2011
I have had this problem for all time on xp, osgeo4w. updating and new dev,
nothing has fixed it. Now I find a page that says this env is not supposed
to be used anymore.
1. Is this just my problem?
2. Does anyone know how to fix it?
G_getenv(): Variable GISDBASE not set
Grassbook chapter 11 says: "Programming:
- Since the variable $LOCATION no longer exists, every GRASS shell script
must have at beginning:
eval `g.gisenv`
: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
to work properly.
- Gmakefiles contain a DEP line now (needed to support optional GRASS
shared libraries)
- GISDBASE isn't meant to be an "environment variable", it's a setting in
$GISRC. Although most of the GRASS documentation is totally confused on this
issue, as was some of the code as well (mostly, code written in Bourne
shell, Tcl or PERL; code written in C used G_getenv(), which got it right).
If I can start grass from any of the interfaces. And I can see my
configuration is set in each of those interfaces. Why does grass plugin
(qgis) not detect that same getenv?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110128/0330f963/attachment.html>
