[Qgis-user] Assigning/warping projections
Jean-Claude Repetto jcrml2 at mxm.eu
Fri Jul 1 00:47:06 PDT 2011
Le 30/06/2011 19:28, Lee Mueller a écrit :
> First, will I be able to use EPSG values for the projection assignment
> with this method?
Look at the file ecw_cs.wkt for the list of the datums and projections
that GDAL supports. If needed, you can add other projections and datums
to this file.
> Second, I'm getting the following error on make. ECW sdk was previously
> installed from source the same time as qgis.
I told you in my previous mail : The libtool file should probably be
updated. Try to compile it manually :
g++ -o ecwhed -l pthread  ecwhed.cpp /usr/lib64/libecwj2.a
(the path for libecwj2 may be different on your system).
Jean-Claude
