[Qgis-user] file ecw and mrsid in ubuntu doesn't work
Lee muellerl at gmail.com
Mon Jul 4 10:09:14 PDT 2011
I did this successfully again today on a fresh install. For ECW the
following method has worked for me:
   1. open terminal
         2.
         sudo wget
         http://de-mirror.org/distro/gentoo/distfiles/libecwj2-3.3-2006-09-06.zip
         3.
         unzip libecwj2-3.3-2006-09-06.zip
         4.
         cd libecwj2-3.3
         5.
         ./configure
         6.
         make
         7.
         sudo make install
         8.
         sudo gdal-ecw-build /usr/local/ (This step may differ depending on
         your file system)
         9.
         sudo ldconfig
         10.
         gdalinfo –formats | grep -i ecw
Make sure in the last step the output shows. If it does not, the install
failed.
I still have yet to successfully incorporate MrSID support. If you manage
it, please let me know.
On Mon, Jul 4, 2011 at 6:25 AM, Giovanni Manghi
<giovanni.manghi at gmail.com>wrote:
> you need the SDKs from erdas and lizardtech
> cheers
> -- Giovanni --
> On Mon, 2011-07-04 at 18:24 +0800, ahmad jauhari wrote:
> > dear all,
> > i have installed gdal-ecw-src and gdal-mrsid-src, but qgis program can
> > not access the file .ecw and file mrSID,  anyone can help me. thanks.
> Qgis-user mailing list
all the best,
Lee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110704/242072cb/attachment.html>
