[Qgis-user] file ecw and mrsid in ubuntu doesn't work
Noli Sicad
nsicad at gmail.com
Tue Jul 5 00:31:43 PDT 2011
It did not work / compile in Mac OS X.
See the logs.
config.status: creating include/icc34.h
config.status: creating include/Makefile
config.status: creating jpegicc/Makefile
config.status: creating python/Makefile
config.status: creating samples/Makefile
config.status: creating testbed/Makefile
config.status: creating tifficc/Makefile
config.status: creating src/Makefile
config.status: executing depfiles commands
./configure: line 19910: cd: /Volumes/SPARE/A_Development/Sandbox: No
such file or directory
./configure: line 19960: Source/NCSBuildGnu/NCSGnuSystemDefs.h: No
./configure: line 19964: Source/NCSBuildGnu/NCSGnuSystemDefs.h: No
./configure: line 19967: Source/NCSBuildGnu/NCSGnuSystemDefs.h: No
configure: creating ./config.status
uniq: confdefs.h: No such file or directory
config.status: creating Makefile
config.status: error: cannot find input file: Source/Makefile.in
localhost:libecwj2-3.3 root#
Noli
On 7/5/11, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 07/04/2011 07:09 PM, Lee wrote:
>> I did this successfully again today on a fresh install. For ECW the
>> following method has worked for me:
>> 1. open terminal
>> 2.
>> sudo wget
>> http://de-mirror.org/distro/gentoo/distfiles/libecwj2-3.3-2006-09-06.zip
>> 3.
>> unzip libecwj2-3.3-2006-09-06.zip
>> 4.
>> cd libecwj2-3.3
>> 5.
>> ./configure
>> 6.
>> make
>> 7.
>> sudo make install
>> 8.
>> sudo gdal-ecw-build /usr/local/ (This step may differ depending
>> on
>> your file system)
>> 9.
>> sudo ldconfig
>> 10.
>> gdalinfo –formats | grep -i ecw
>> Make sure in the last step the output shows. If it does not, the install
>> failed.
> This worked for me on Ubuntu Natty, self build qgis, gdal 1.8.0
> Only last step 10 I could not copy paste because of --
> gdalinfo --formats | grep -i ecw
> Thanks!
> Qgis-user mailing list
