[Qgis-user] Problem loading vector layer in python
Richard Duivenvoorde
rdmailings at duif.net
Tue Jul 5 13:18:48 PDT 2011
On 07/05/2011 12:40 PM, Viktor Kalén wrote:
> Layer failed to load!
> I'm using the OSGeo4W installation, on Windows 7, python 2.52, 32 bit.
> I'm using pyscripter.
> What am I doing wrong here?
Hi Viktor,
tried your lines here on linux. And layer was valid.
Did you set all paths ok see also:
http://www.qgis.org/pyqgis-cookbook/intro.html
It's easier testing by just testing line by line:
Start python and start with the line:
import sys, os
then try line by line
it will throw errors on the lines that are failing (for mine eg it was
that I first had to set the PYTHONPATH and LD_LIBRARY_PATH. But after
that all was fine.
Regards,
