[Qgis-user] Bugs
    Lee
    muellerl at gmail.com
    Thu Jul  7 07:49:32 PDT 2011
Perfect. Glad that is working for you. It might be worthwhile to mention the
bug tracker issue when you contact the dev list. I've never tried to use it,
but if it's down or difficult to use, it should probably be mentioned.
On Thu, Jul 7, 2011 at 10:45 AM, <jonathanmoules at warwickshire.gov.uk> wrote:
> Lee,
>         Yep, you're probably right about belonging on the dev list (I'll
> probably do that later when I have the time). I'd have preferred to put them
> (at least the apparently bugs) onto the bugs tracker directly but of course
> I can't seem to create an account.
>         Incidentally, the ECW issue wasn't related to ECW's, but was a
> limitation of QGIS and it's default settings (it happened with the open
> JP2's too). Now that I've changed the setting per Nathan's suggestion, ECW's
> are working fine.
> Jonathan
> From:        Lee <muellerl at gmail.com>
> To:        jonathanmoules at warwickshire.gov.uk
> Cc:        Andreas Neumann <a.neumann at carto.net>, Nathan Woodrow <
> madmanwoo at gmail.com>, qgis-user at lists.osgeo.org
> Date:        07/07/2011 15:27
> Subject:        Re: [Qgis-user] Bugs
> I recommend some of your comments for changes/incorporated ideas be
> directed to the qgis developer list-serv. This listserv is primarily
> utilized by users of the program for quick help and questions. Although I'm
> sure some of the developers peruse it .
> I agree with Andreas. When it comes to open-source software there can
> generally be some issues with proprietary formats. When the formats are
> changed, or the distribution arrangements are altered, there is usually some
> period of time lapse before they can adequately be adopted. If this is an
> issue, I recommend communicating your concerns with those companies that
> provide the formats and encourage them to standardize in a fashion that can
> easily be utilized by the open source community.
> Personally, I generally convert all my ECW's to another format in case the
> SDK changes again (which is the problem many users are currently dealing
> with).
> On Thu, Jul 7, 2011 at 10:10 AM, <*jonathanmoules at warwickshire.gov.uk*<jonathanmoules at warwickshire.gov.uk>>
> wrote:
> Hi Andreas, Nathan
>         Thanks for the prompt Replies.
> > the infrastructure was just changed recently. Did you try on *
> http://hub.qgis.org/* <http://hub.qgis.org/>- personally I don't know how
> the accounts are handled. The old accounts from *trac.osgeo.org*<http://trac.osgeo.org/>were
> migrated.
> This in turn points to the same bugs page. It allows "sign in", but there's
> no "register" button that I can see.
> >  Personally, I would really stay away from proprietary formats like ecw
> and mrsid.
> In principle I agree, but this is one of the few formats that's supported
> across all our applications internally (the other being JP2000), so it's
> what we've put our data into. We can easily convert the data into pretty
> much any raster format at any time as it's almost all sourced from Ordnance
> Survey TIF's, but we'd prefer not to have multiple versions of each raster.
> JP2000 seems to be a fairly open standard (it's ISO defined), even if it
> doesn't have much uptake.
> I've found a smaller ECW file - 27MB. QGIS hangs for a little over a minute
> when loading this. Extrapolating that up to the 4GB file gives 2.5hrs to
> load it! QGIS is also using an absurd amount of RAM (~700MB) just to display
> this single layer. ArcMap tells me this file is 260.35 MB uncompressed.
> However, following Nathan's suggestion, I have disabled the "Contrast
> Enhancement", and it is now loading all of the aforementioned rasters just
> fine. It's also not using absurd amounts of RAM. I'd humbly suggest making
> this the default.
> >  Did you set the projection of your QGIS project? It sounds like this is
>  set to WGS84/degrees. Try to set it to your british national grid and it
> will probably work fine.
> Nope. I'm lazy and used to applications automatically detecting the
> projection of the first layer added and using that for the project (aka
> ArcGIS) ;-) . After some fiddling I found 27700 and it's now correctly
> showing km. But it would be nice if it picked up the projection from the
> first dataset, you can always change it later.
> > This is because you probably enabled the "Copyright plugin", which is
>  not enabled by default, I think.
> I haven't changed any of the plugins (or indeed, any settings whatsoever),
> they're all on default. I suspected it was for showing your own copyright,
> but couldn't see it in the options page. Even now that I know where it is
> (plugins), there's no obvious way to change the text, only enable/disable it
> via "manage plugins". Not that this is important to me, it's just weird
> having someone else's copyright on my map by default.
> Thanks again,
> Jonathan
> From:        Andreas Neumann <*a.neumann at carto.net* <a.neumann at carto.net>>
> To:        <*qgis-user at lists.osgeo.org* <qgis-user at lists.osgeo.org>>
> Date:        07/07/2011 14:15
> Sent by:        *qgis-user-bounces at lists.osgeo.org*<qgis-user-bounces at lists.osgeo.org>
>  Hi Jonathan,
> I can only partially answer your questions/remarks.
> >  A few bugs with QGIS 1.7.0. Unfortunately there's no obvious way to
> > actually create an account or report bugs on your bug tracker so I'm
> > forced to post them here.
> **http://hub.qgis.org/* <http://hub.qgis.org/>
> - personally I don't know how the accounts are
> handled. The old accounts from *trac.osgeo.org* <http://trac.osgeo.org/>were
> migrated.
> > 1) I have a ~600MB raster in JP2000 format (*.jp2). QGIS doesn't seem
> > to be able to load this, at least not in a timely manner. It spent at
> > least 5 mins sitting there eating 100% CPU and using quite a bit of
> > RAM.
> > I also have a ~4GB ECW file which similar things happen with. Both
> > files are projected (OSGB - 27700) and I'm fairly sure they have
> > pyramids.
> > MapInfo, ArcGIS, MapModeller (all proprietary), and MapWindow (Open
> > Source) are all capable of displaying both images in fractions of a
> > second.
> There has been a lot of mail recently about the problems with ecw.
> and mrsid. You will never know when those companies changed their
> policies and if they care about compatibility with OS GIS. I personally
> use TIFF files (bigtiff files are more or less unlimited in size), and
> you can choose between different compressions in the tiff, like jpeg,
> deflate, zip, packbits, etc. These files usually work fine. I never had
> any issues. Back 2-3 years I also experimented with ecw and always ran
> into issues with software upgrades.
> This doesn't mean that the bug should not be fixed, but it is a
> recommendation about storing your data.
> > 2) I load a shapefile that's projected in British National Grid into
> > QGIS. The built in QGIS scale shows "degrees" rather than "metres" as
> > the measurement unit despite showing "0" to "30,000" numerically (so
> > it is showing metres, it's just incorrectly saying "degrees". This is
> > to a new map that has no other layers added.
> > 3) Why is there a "(c) QGIS 2011" in the bottom right of the map
> > viewer? 99% + of other programs use the Help->About page for that.
> not enabled by default, I think. You can easily disable it in the
> plugins manager. The goal of the copyright plugin is not showing the
> QGIS copyright, but your own copyright (e.g. your company). You can
> easily configure it to show your own copyright, or better disable it
> alltogether. For configuration look into the Plugins toolbar and the
> button with the copyright symbol.
> Hope this helps,
> Andreas
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> Qgis-user mailing list
> **Qgis-user at lists.osgeo.org* <Qgis-user at lists.osgeo.org>*
> **http://lists.osgeo.org/mailman/listinfo/qgis-user*<http://lists.osgeo.org/mailman/listinfo/qgis-user>
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list*
> all the best,
> Lee
all the best,
Lee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110707/27a09eff/attachment.html>
