[Qgis-user] Does QGIS understand MapServer CGI?
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Mon Jul 11 14:40:07 PDT 2011
All,
Sorry, re-thought this some, and got another idea. Is there a method for adding a layer (or layers) to QGIS either from the commandline preferably directly from the web or via an external script of some sort?
bobb
>>> "Bob Basques" <Bob.Basques at ci.stpaul.mn.us> wrote:
Pirmin,
I'm interested in the MapFile making abilities, but the importing of the map view from our systems is the higher priority (first). :c)
Maybe the Openlayers importing would only be intended for display purposes. For example, a OpenLayers (like Dialog in place of the WMS connector) would be easier to teach others to use for grabbing layers and pulling them into QGIS for example, a Radio button / checkbox per layer??. Does this make it easier, or harder?
bobb
>>> Pirmin Kalberer <pi_ml at sourcepole.com> wrote:
Bob,
Am Montag, 11. Juli 2011, 23.10:01 schrieb Bob Basques:
> Pirmin,
> I've tried the MAPFILE maker in the past (not recently). It seemed to work
> ok at the time I tried it.
I'm not sure, we're talking about the same plugin. My on is titeled "Mapfile
tools" in the plugin installer.
> I'm more interested in going in the other direction though, something
> similar to the WMS importing, but with better user control over how things
> look in the mapping interface.
> This may sound like a weird request/idea, but what about embedding a
> OpenLayers (like) view inside of the MapView in QGIS? Or even a mechanism
> for importing any Web Based mapping system (mapview aspects, really only
> need to translate the projection of QGIS to the mapping interface view)
> into the Map view window of QGIS?
> Our MapServer implementation looks like this currently:
> http://gis.ci.stpaul.mn.us/gis/gismo_public/html/
> And a Simple OpenLayers version of the same data might look like this:
> http://pwultra5.ci.stpaul.mn.us/ol/ol.05.html
> I'm interested in any ideas related to importing MapServer services into
> QGIS with similar easier to use, user controls.
Since OpenLayers actually supports native UMN MS control, including such a
layer in the OpenLayers plugin (http://hub.qgis.org/projects/openlayers) could
be an option.
The problem with adding additional user controls is, that you have to redirect
mouse clicks on the map canvans to openlayers.
Pirmin
> NOTE: BTW, while this seems like a left hand idea, I do something similar
> for importing these same data into Our AutoCAD workstations as well. QGIS
> with the same capability would round things out very nicely in the Open
> Source side of things.
> Thanks
> bobb
> Bob,
> Am Montag, 11. Juli 2011, 22.12:25 schrieben Sie:
> > Pirmin,
> > Yes, I have the WMS side of things working already against our server,
> > but it's a bit cumbersome to teach folks how to use via the WMS methods.
> > I'm wondering about what it would take to build in MapServer CGI
> > connectivity in some form. Is there a path to look at that could
> > replicate MapScript or PERL for assembling the MapServer CGI calls? The
> > WMS controls are not very adaptable to our 300 plus layer setup either.
> If you're running Linux, the UMN Mapserver plugin could be interesting for
> you:
> http://hub.qgis.org/projects/qgis-mapfile-tools/wiki
> It renders UMN map files with Python MapScript.
> Pirmin
> > One other thing I've not had much success in implementing via WMS is the
> > legend creation for layers, there does not seem to be much flexibility
> > with regard to legend generation, if at all, with WMS (at least not for
> > myself).
> > Thanks for the information.
> > bobb
> > Hi Bob,
> > You can use UMN Mapserver CGI as WMS. This is supported. Using the UMN
> > specific CGI parameters is not supported.
> > Regards
> > Pirmin
> > Am Montag, 11. Juli 2011, 21.41:05 schrieb Bob Basques:
> > > All,
> > > Can QGIS make calls to MapServer CGI direclty, out of the box?
> > > Thanks
> > > bobb
> > Pirmin Kalberer
> > Sourcepole - Linux & Open Source Solutions
> > http://www.sourcepole.com
> Pirmin Kalberer
Pirmin Kalberer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110711/f16b4c65/attachment.html>
