[Qgis-user] trouble adding postgis(2.0) layer to qgis(1.6)
John Callahan
john.callahan at udel.edu
Mon Jul 18 17:21:35 PDT 2011
I do not believe PG 2.0 is supported in QGIS 1.6. I had a similar error
when I had tried. It does work well using QGIS 1.7 or greater.
- John
On Mon, Jul 18, 2011 at 7:45 PM, Vishal Mehta <vishal.mehta at sei-us.org>wrote:
> Hi all,****
> I’m using Quantum GIS 1.6.0, ****
> Postgresql 9.0 and ****
> Postgis 2.0 (dev version)**
> On Windows 7.****
> I’m having trouble adding a Postgis layer to QGIS. I loaded a shapefile
> into my database separately using the shapefile loader and that seemed to
> woork fine. However when I try to bring it into QGIS I get the following
> error:****
> *1 cursor states lost.*
> *SQL: declare qgisf1 binary cursor for select "gid",asbinary("geom",'NDR')
> from "public"."wardscleanattributes" where "geom" &&
> setsrid('BOX3D(-1.2547169811320755 -1.0000000000000000, 1.2547169811320755
> 1.0000000000000000)'::box3d,-1)*
> *Result: 7 (ERROR: function asbinary(geometry, unknown) does not exist*
> *LINE 1: declare qgisf1 binary cursor for select "gid",asbinary("geom...*
> *HINT: No function matches the given name and argument types. You might
> need to add explicit type casts.*
> The layer has a gist index, as well as a serial, primary key column.****
> The same procedure used to work fine with****
> QGIS 1.0.2 – postgresql 8.3 and postgis 1.5****
> Help?****
> Vishal****
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110718/ed909a9e/attachment.html>
