[Qgis-user] install qgis server on RHEL?
Volker Fröhlich volker27 at gmx.at
Wed Jul 20 02:06:06 PDT 2011
Dear Richard!
Use the ELGIS repository for QGIS 1.6 or rebuild the Fedora package for QGIS
1.7.
http://elgis.argeo.org/
http://koji.fedoraproject.org/koji/buildinfo?buildID=251886
The best solution is to rebuild with "mock". Mock spares you from installing
development packages on your host and you can also build packages for other
distribution or versions, e. g. RHEL 5.
http://fedoraproject.org/wiki/Projects/Mock
$ mock --rebuild -r epel-6-x86_64 <your_srpm>
Quick and dirty rebuild:
- Install rpm-build
(You may have to create the build tree directory structure with rpmdev-
setuptree, or something).
- Download the SRPM
- # yum-builddep <your_srpm>
- $ rpmbuild --rebuild <your_srpm>
Instructions and a sample configuration for QGIS-Server are included in the
Fedora package "qgis-mapserver".
Locate the documentation after installing by: $ rpm -qd qgis-mapserver
Volker
Am Mittwoch, 20. Juli 2011, 10:40:24 schrieb Richard Duivenvoorde:
> Hi List,
> I have a RHEL6 demo machine running.
> I want to install/demo qgis-server on it.
> What is the easiest way to install that?
> Normal compile of qgis? (gdal/proj is already done there for
> mapserver...), or are there easier packages available (like for ubuntu).
> Grtz
> Richard
> Qgis-user mailing list
