[Qgis-user] Offline Editing combined with PgVersion
maning sambale
emmanuel.sambale at gmail.com
Fri Jul 22 04:59:11 PDT 2011
Dear Horst,
I noticed you published pg_version 0.9 and gave it a run. The process are:
1. Connect to the postgis db and load a layer (i.e. pg_layer ).
2. Prepare the loaded layer for versioning. This creates a new layer
(i.e. pg_layer_version)
3. Convert the pg_layer_version to offline spatialite db
(pg_layer_version(offline))
4. Edit the offline version.
6. Connect to the pg db.
7. Synchronize the offline spatialite. The changes are merged into
the pg_layer_version.
8. Commit changes from the pg_layer_version to the main pg_layer.
Is this the correct workflow? I managed to test a few commits and it
seems to work.
A few observations I noticed:
1. Synchronizing the offline spatiallite db to the pg_layer_version
takes considerable time even if I simply edited a single vertex and
attribute. (PG is on the same machine).
2. After creating and editing the offline spatialite, I closed QGIS.
I opened again and tried editing. I cannot synchronize anymore. I'm
sure my current session is connected to the pg db. Perhaps a bug in
the spatialite plugin "losing the connection to pg".
I haven't worked out how to revert but the initial implementation is
looking good. Very similar to git's clone/fork-edit-stage
commits-push to remote. :) Will test some more and provide feedback.
This is using qgis 1.7 on Ubuntu 11.04.
On Thu, Jul 21, 2011 at 5:37 PM, Horst Düster <horst.duester at kappasys.ch> wrote:
> Hi
> I followed the discussion about the combination of offline editing and
> pgversion in the last week. In my opinion it is very easy to combine these
> two features. You only have to load a versioned layer. Than prepare this
> layer for offline editing. After finishing your edits you syncronise the
> offline editings with the versioned layer. Now you can commit your editings
> to the main repository. Thats all. The only issue is at the moment, that the
> versioned layer is not marked as modified. But this will be solvable.
> In the afternoon I will publish a new version 0.9.0 of pgversion with the
> option to display commit logs.
> Regrads
> Horst
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
