Virtual columns in QGIS, was: Re: [Qgis-user] object labels
Andreas Neumann a.neumann at carto.net
Thu Jul 28 00:43:32 PDT 2011
 Hi Nathan,
 Good to hear that you are working on this.
 I just wonder if it wouldn't make sense to have a general purpose
 "virtual column" that could be introduced in QGIS. This would be useful
 for:
 * labeling
 * map tips/QGIS server tooltip display
 * symbology
 * plugins
 * others?
 It would be convenient to use the field calculator, but instead of just
 writing out to a physically existing column it would create a new
 virtual column, just like a virtual column in a database view.
 Otherwise one would have to develop the same functionality several
 times - for labeling, for tooltips, etc.
 Do you think it would be feasible to implement this on a lower level in
 QGIS so that users could transparently work with virtual columns
 wherever they want?
 Andreas
 On Thu, 28 Jul 2011 16:09:56 +1000, Nathan Woodrow wrote:
> My upcoming patch that adds expression based labels will be able
> to achieve this once it's completed;  I'm just cleaning up the UI
> and testing everything then I will get the guys to merge it in.
>  Until then you will need to create a new column.
> - Nathan
> On Wed, Jul 27, 2011 at 9:15 PM, Torsten Lange  wrote:
>> Ok, thank you, Andreas!
>> Torsten
>> Am Mittwoch 27 Juli 2011, 11:00:01 schrieb Andreas Neumann:
>>>  Hi,
>> >  Currently, you have to create a new column. I usually create a
>> view in
>> >  Postgis for this purpose.
>> >  It is in on the wishlist that one can create a "virtual" column
>> - not
>> >  only for labeling, but also for map tips and perhaps
>> symbolization.
>> >  Until then you have to do it yourself.
>> >  Andreas
>> >  On Tue, 26 Jul 2011 22:51:34 +0200, Torsten Lange wrote:
>> > > Hi,
>> > > Is there a way just to print - lets say - the first four
>> letters of a
>> > > objects
>> > > name? Or must I create a new row for that?
>> > > Thank you, Torsten
>> > > _______________________________________________
>> > > Qgis-user mailing list
>> > > Qgis-user at lists.osgeo.org [1]
>> > > http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
>> Qgis-user at lists.osgeo.org [3]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user [4]
> Links:
> [1] mailto:Qgis-user at lists.osgeo.org
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [3] mailto:Qgis-user at lists.osgeo.org
> [4] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [5] mailto:tlange at gwdg.de
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
