[Qgis-developer] Virtual columns in QGIS, was: Re: [Qgis-user] object labels
Nathan Woodrow
madmanwoo at gmail.com
Thu Jul 28 03:03:25 PDT 2011
Yeah those are possible. Not 100% sure with point 2 but the others can be
done. QGIS uses || for concatenation too.
On Thu, Jul 28, 2011 at 7:45 PM, kimaidou <kimaidou at gmail.com> wrote:
> Hi
> Since I have not tested your patch yet, it is hard to comment. The
> functionnalities I am thinking of for labelling purpose are :
> * be able to add uppercase to the first letters of words
> * add a line break after the first space after X letters (such as Mapserver
> does with WRAP and MAXLENGTH ( http://mapserver.org/mapfile/label.html )
> * Concatenate one or more columns with expresssions, such as : colA || '('
> || colB || ')' (here I am using the postgresql || syntaxe )
> kimaidou
> 2011/7/28 Nathan Woodrow <madmanwoo at gmail.com>
>> +1 from me too. A virtual column would be a very handy feature however
>> you must be able to add one to read only datasets eg MI Tab otherwise their
>> is no real advantage. The expression labelling I'm working on works with
>> read only datasets. I think the expression based labelling and the virtual
>> column thing could exist together quite well the former being a short cut in
>> the labeling gui for the latter.
>> Check out http://hub.qgis.org/issues/3488 and
>> https://github.com/NathanW2/Quantum-GIS/tree/expression-labels for the
>> status of my patch. I have been away for a couple of weeks but I will be
>> getting back into over the next couple of weeks.
>> Anyone else got any other thoughts?
>> - Nathan
>> On Thu, Jul 28, 2011 at 6:49 PM, kimaidou <kimaidou at gmail.com> wrote:
>>> Hi,
>>> +1 for Mayeul Nathan. This "virtual column" would be a very handy tool !
>>> E.G for labelling
>>> kimaidou
>>> 2011/7/28 Andreas Neumann <a.neumann at carto.net>
>>>> Hi Nathan,
>>>> Good to hear that you are working on this.
>>>> I just wonder if it wouldn't make sense to have a general purpose
>>>> "virtual column" that could be introduced in QGIS. This would be useful for:
>>>> * labeling
>>>> * map tips/QGIS server tooltip display
>>>> * symbology
>>>> * plugins
>>>> * others?
>>>> It would be convenient to use the field calculator, but instead of just
>>>> writing out to a physically existing column it would create a new virtual
>>>> column, just like a virtual column in a database view.
>>>> Otherwise one would have to develop the same functionality several times
>>>> - for labeling, for tooltips, etc.
>>>> Do you think it would be feasible to implement this on a lower level in
>>>> QGIS so that users could transparently work with virtual columns wherever
>>>> they want?
>>>> Andreas
>>>> On Thu, 28 Jul 2011 16:09:56 +1000, Nathan Woodrow wrote:
>>>>> My upcoming patch that adds expression based labels will be able
>>>>> to achieve this once it's completed; I'm just cleaning up the UI
>>>>> and testing everything then I will get the guys to merge it in.
>>>>> Until then you will need to create a new column.
>>>>> - Nathan
>>>>> On Wed, Jul 27, 2011 at 9:15 PM, Torsten Lange wrote:
>>>>> Ok, thank you, Andreas!
>>>>>> Torsten
>>>>>> Am Mittwoch 27 Juli 2011, 11:00:01 schrieb Andreas Neumann:
>>>>>> Hi,
>>>>>> > Currently, you have to create a new column. I usually create a
>>>>>> view in
>>>>>> > Postgis for this purpose.
>>>>>> > It is in on the wishlist that one can create a "virtual" column
>>>>>> - not
>>>>>> > only for labeling, but also for map tips and perhaps
>>>>>> symbolization.
>>>>>> > Until then you have to do it yourself.
>>>>>> > Andreas
>>>>>> > On Tue, 26 Jul 2011 22:51:34 +0200, Torsten Lange wrote:
>>>>>> > > Hi,
>>>>>> > > Is there a way just to print - lets say - the first four
>>>>>> letters of a
>>>>>> > > objects
>>>>>> > > name? Or must I create a new row for that?
>>>>>> > > Thank you, Torsten
>>>>>> > > ______________________________**_________________
>>>>>> > > Qgis-user mailing list
>>>>>> > > Qgis-user at lists.osgeo.org [1]
>>>>>> > > http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>[2]
>>>>>> Qgis-user at lists.osgeo.org [3]
>>>>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>[4]
>>>>> Links:
>>>>> [1] mailto:Qgis-user at lists.osgeo.**org <Qgis-user at lists.osgeo.org>
>>>>> [2] http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>> [3] mailto:Qgis-user at lists.osgeo.**org <Qgis-user at lists.osgeo.org>
>>>>> [4] http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>> [5] mailto:tlange at gwdg.de
>>>> Andreas Neumann
>>>> Böschacherstrasse 10A
>>>> 8624 Grüt (Gossau ZH)
>>>> Switzerland
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110728/281be1f1/attachment.html>
