[Qgis-user] POSTA CERTIFICATA: Installing QGIS: severe error
Milo van der Linden milo at dogodigi.net
Wed Jun 1 11:41:11 PDT 2011
Your system might have older versions of that dll hanging around. Please
perform a search for the file and check for duplicates. Qgis installs dll's
in its own directory, other found versions could be outdated
Met vriendelijke groet,
Milo van der Linden
verzonden vanaf een smartphone met onhandig toetsenbord. Typefouten? Vergeef
mij!
Op 1 jun. 2011 19:50 schreef "Per conto di: resambiente at legalmail.it" <
posta-certificata at legalmail.it> het volgende:
> Messaggio di posta certificata
> Il giorno 01/06/2011 alle ore 19:36:26 (+0200) il messaggio
> "Installing QGIS: severe error" e' stato inviato da "
> indirizzato a:
> qgis-user at lists.osgeo.org
> Il messaggio originale e' incluso in allegato.
> Identificativo messaggio:
382171734.1267177073.1306949786842liaspec02 at legalmail.it
> L'allegato daticert.xml contiene informazioni di servizio sulla
trasmissione.
> Legalmail certified email message
> On 2011-06-01 at 19:36:26 (+0200) the message "Installing QGIS: severe
error" was sent by "resambiente at legalmail.it"
> and addressed to:
> The original message is attached with the name postacert.eml or Installing
QGIS: severe error.
> Message ID: 382171734.1267177073.1306949786842liaspec02 at legalmail.it
> The daticert.xml attachment contains service information on the
transmission.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110601/990f8a22/attachment.html>
