[Qgis-user] how to build new symbol?
    Matt Boyd
    mattslists at gmail.com
    Tue Jun  7 05:28:32 PDT 2011
ESRI has a lot of symbols installed as fonts which works pretty well
for point layers in QGIS. If you've previously installed ARC on the
same PC you can use use a symbol from a font for the symbol. I don't
recall the exact steps but it must have been pretty simple if I
figured it out.
You can also hunt for the fonts directory on an PC that's had ARC
installed, select the esri fonts and install them on another machine
or OS.
On Wed, Jun 1, 2011 at 1:39 PM, mega saputra <megasapu at gmail.com> wrote:
> Hi,
> I usually work in arcgis 9.3. I will try work using QGIS 1.6.0 on windows 7.
> In ArcGIS, I can see more example symbol like ESRI, forestry, geology, and
> so much. So, I can choose a proper symbol for a class.
> In QGIS, where is it? May be no example symbol like ArcGIS. May be in QGIS,
> user has to build new symbol his self. So, how to do it?
> Thanks for anyone help me.
> Qgis-user mailing list
