[Qgis-user] LIBMYSQL.dll "procedure entry point my_init" not found
Saber Razmjooei
razmjooeis at faunalia.co.uk
Fri Jun 10 06:14:45 PDT 2011
First make a back up of LIBMYSQL.dll
Then re-install QGIS. It will overwrite LIBMYSQL.dll. Hopefully XAMPP is
happy with QGIS version of LIBMYSQL.dll
If not, you can copy the backed-up version of XAMPP to the application
folder, not to the system-wide one (C:\windows\system32 in WinXP 32 bit).
Hope that helps
> Hi,
> Has anyone had this error message come up when loading QGIS before?
> "The procedure entry point my_init could not be located in the dynamic
> link
> library LIBMYSQL.dll"
> QGIS was working fine, so this must be due to my new installation of
> XAMPP,
> which obviously contains MySQL.
> I'm not sure how I go about fixing this, as I need to use XAMPP. If anyone
> can help I would be grateful!
> Cheers,
> Rob
> Qgis-user mailing list
