[Qgis-user] FW: Esri File Geodatabase API Is Now Available
    Alex Mandel
    tech_dev at wildintellect.com
    Fri Jun 10 10:03:56 PDT 2011
It was on the download page. It clearly said single user, which is why I
mentioned it would be similar to how ECW works - the user has to go
download the SDK and add the plugin the gdal.
But I doubt it says no server since they did Release it for Redhat. But
I encourage people to read the details more closely.
Thanks,
Alex
On 06/08/2011 06:17 AM, David Fawcett wrote:
> I can't find a link to the TOU/License, but early on, I believe that
> there were some restrictions like single-user, no server installs.
> That may have changed.
> David.
> On Wed, Jun 8, 2011 at 1:30 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
>> Il 07/06/2011 23:08, Advrk Aplmrkt ha scritto:
>>> YES. Our lab is trying to get out of the ArcGIS licencing "trap" which
>>> is prohibitively costly.
>>> The key would be a relatively easy way for us to convert our existing
>>> library of Arc geodatabases.
>>> Hope such a feature appears in QGIS very soon.
>> I think your best option is to save shapefiles and convert them to either PostGIS or
>> SpatiaLite. The disadvantage is that you have to rebuild views and joins, but I think
>> this option is easier and more reliable than others.
>> All the best.
>> Paolo Cavallini: http://www.faunalia.it/pc
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
